Do you have an expected release date when you will update the MySQLi extension to work with Dreamweaver CC 2015?
Thread began 6/30/2015 1:54 am by Richard | Last modified 9/28/2015 9:57 am by Ray Borduin | 2417 views | 9 replies |
Richard
I know you are having UI problems with the new Release of CC 2015 from Adobe, but do you have an expected release date for the update to the MySQLi Extension for Dreamweaver?
Thanks in anticipation for your speedy response.
We are in the middle of updating the product line. It will likely take a week or two to get it all tested and released.
Me
I am now running Dreamweaver CC (2015). I downloaded the latest MySQLi extension (1.0.4) update and tried to install with Extension Manager CC. Just so we're sure it was the MySQLi104.zxp But, when I do, I get this...
Error: "This extension can not be installed, it requires Dreamweaver 9 or greater"
Just to recap;
DW = Dreamweaver CC (Release 2015.0 - Build 7714)
EM = Extension Manager CC (Version: 7.3.2.39)
MySQLi104.zxp Won't install - See Error Above
WAeCart611.zxp Won't install - See Error Above
Please advise
juergen
I got the same error
Whats hapening with this extension i buy this extension today and it doesnt work :-[ ."Error:
What should i do to get my money back?
This is a Dreamweaver issue where the extension manager isn't recognizing that you do have a more recent version of Dreamweaver installed. You can follow the steps here to get it installed: http://www.webassist.com/forums/posts.php?id=37620
studio433084
refund for non working add on
I am using cc 2015 and this is not working. I have tried all posted solutions to no avail. I have waisted over 7 hours. Seems web assist should pay me as a beta tester.
Email refund requests to us directly using sales@webassist.com. Just include your order number or serial number and we will process the refund.
Colin
try to use this way to instead for now
https://helpx.adobe.com/x-productkb/global/installingextensionsandaddons.html
work for me
juergen
this extension sucks
with the https://helpx.adobe.com/x-productkb/global/installingextensionsandaddons.html command line tool as an administrator i could install and activate the extension. But it doesn t work.
After model database the connection is not created after restart the program the connection is created now.
but it is not possible to work with a recordset there is no window to activate database and recordset in DW i installed so many extensions from dmxzone and i had no problems.
You need to also install the "Deprecated Server Behaviors" extension from Adobe in order to interact with databases and apply server behaviors.
