Captcha image does not display
Thread began 6/23/2015 2:07 pm by Charles | Last modified 6/25/2015 7:29 pm by Ray Borduin | 409 views | 5 replies |
Charles
Created pages using SecurityAssist. Captcha image does not display. Read the thread where you suggested to remove semicolon from php.ini file from line that contained 'gd2.' I checked that and there is no semicolon before that line. Any other suggestions?
Using Wamp server and the code created by SA for my registration.php file is
<img src="webassist/captcha/wavt_captchasecurityimages.php?field=Security_Code&amp;noisefreq=15&amp;noisecolor=060606&amp;gridcolor=080808&amp;font=fonts/MOM_T___.TTF&amp;textcolor=040404" alt="Security Code" class="Captcha">
I'll add that I ran the phpinfo,php as suggested in your tutorial and GD is enabled.
What is the URL to the page so I can take a look.
Charles
It is on my local wamp server. Since you can't view it there, I have attached a copy of registration.php. Hopefully that's sufficient info for you.
registration.php
There is nothing wrong I can see with the page.
Maybe replace the &amp; in the src with just an &
<img src="webassist/captcha/wavt_captchasecurityimages.php?field=Security_Code&noisefreq=15&noisecolor=060606&gridcolor=080808&font=fonts/MOM_T___.TTF&textcolor=040404" alt="Security Code" class="Captcha">
Could you put it up to a live location so I could view it? I think that may be necessary to debug any further.
Charles
Captcha seems to load fine on the live server registration page - see http://outofchaos.net/gsc/www/registration.php
Just can't make it work on my local wamp server. I suppose I can Import the User table from the Live server to trick my test server for testing purposes unless you have another suggestion. Thanks . . .Charlie
It must be an issue with the GD library or freetype installation on your local server. I'm not an expert at server configuration, but if it works on the live site that means it isn't an issue with the code.
