Redirect not working after record update form submitted
Redirect on record submit not working. Seems to be a problem with the $UpdateGoTo or the rel2abs function. This works on insert and delete but not on update???? Any ideas?
The problem appears to be library.php does not exsist in the webassist folder which is causing this function not to work:
if (function_exists("rel2abs")) $DeleteGoTo = $DeleteGoTo?rel2abs($DeleteGoTo,dirname(__FILE__)):"";
$DeleteQuery->redirect($DeleteGoTo);
In researching online it looks as if the function rel2abs is supposed to be in the library.php file installed in this path "'webassist/framework/library.php'". My webassist folder does not have a framework folder or a library.php file. Can you send me this file or provide a location to download it?
