adope dreamweaver cs5.5 has stopped working ,how can i reslove
we using windows 8 os,please do the needful.
You can try renaming your user's configuration folder.
Open windows explorer and type in: %appdata%
Then browse to: Adobe/Dreamweaver CS5.5/en_us
Rename the Configuration folder to Configuration_bad
That will effectively remove all extensions and restore Dreamweaver to default functionality. Then try starting Dreamweaver. If it still won't start, then you will have to reinstall Dreamweaver.
