No tables in Webassist data modeling
I am able to connect to the database with the test button. When I start a data model tool, I don't see any of the tables. Am I doing something wrong? I have tried the root user and other users with any luck.
What version of Dreamweaver and OS are you using? Are you using a local or remote database connection?
Dreamweaver CS6 and Windows 7. Either connection, local or remote gives me the same result.
Export and send me a copy of your Dreamweaver site as a .ste file and I should be able to use that to reproduce the problem and let you know what the cause and fix is for it.
I will also need the FTP username and password to test. Please post it in the private area of a reply.
