eCart multiple pages.
Thread began 4/10/2015 4:46 am by Joao | Last modified 4/17/2015 1:31 pm by Ray Borduin | 1031 views | 6 replies |
Joao
Hello, I have been trying to apply the ecart to a couple of different pages such as a catalogue page were it works prefectly and a serach page where the add to cart button does not add the item to the shopping cart. The only difference between the 2 pages is obviously the recordset settings, one shows the records based in a serach by column content the other one based in a form variable. Is it possible to use the eCart on different pages or not? Regards
Yes, there shouldn't be any issue with using the cart on multiple pages. It must be something about the page causing it to not function properly. If you upload a copy of the page that doesn't work I can take a look and see if I can spot the problem.
Joao
eCart multiple pages issue
Ok heres 2 files one that works perfect "continente.php" and the other that does not "procurar.php". Please have a look. Appreciated.
One obvious problem on that page is that you don't have a form around your IDProd form element. It needs to be inside a form to be passed when the form is submitted.
Joao
Wrong file
It looks like you need to add a hidden field to your add to cart form to pass the procurar field back to the recordset.
Try adding this just before or after the add to cart button in that form:
html:
<input type="hidden" name="procurar" value="<?php echo($_POST['procurar']); ?>">
Joao
html:
Thanks for your help!
