Send two emails Universal Email - Classic ASP version
Thread began 2/27/2015 3:04 am by anonymous | Last modified 3/02/2015 8:55 am by Jason Byrnes | 690 views | 3 replies |
anonymous
We are trying to update an old website that uses classic ASP and universal email (ASP version) to send more than 1 email. We've duplicated the code from the first instance of the Universal email script (we don't have the ASP version of the extension any more) and have changed the variable names and added a second instance of the sendmail function at the end of the script, but the second email isn't being received, despite the redirect being fired correctly. I've attached a zip file with the code included (we've commented out the first instance of sendmail in this file so we don't receive this to make it easier to tell whether the second email is being received). Can anyone help with this code as we can't seem to get it right?
addtoorder-2.asp.zip
your changing the names of variables that shouldn't be changed.
only the function name:
WA_Universal_Email_2_SendMail
should change, none of the other variable names inside the function should get changed.
YellowCircleWeb
Thank you for your help Jason - that works fine now.
you're welcome.
