uploading an image
Thread began 2/23/2015 2:46 pm by Jose | Last modified 2/23/2015 3:23 pm by Jose | 264 views | 0 replies |
Jose
uploading an image
I am following one of your tutorials do upload a page. The tutorial states the following:
Step 3: Updating the Insert Record server behavior
We now need to update the Data Bridge Insert record server behavior to accommodate the file field.
From the Server Behaviors panel, double-click on the Insert Record option.
Click Next.
Select the column you applied the file field to.
Click the value lightning bolt.
Expand the WA Upload File option for your column.
Choose Server File Name.
Click OK.
Click Finish.
I cannot follow instructions. There is no NEXT button. You have 2 tabs...... General and Bindings. Can you expand on these set of instructions? I have been trying to save a file for 2 days with no luck.
By the way,I created my crud pages using the dataassist pages wizard. Defined one of my columns to be "FILE" type and it works when I test. I followed the tutorial and I think I'm doing everything right until I get to step 3
Link to tutorial is: http://www.webassist.com/community/tutorials/view_tutorial.php?tid=18
30 minutes later.......
Now it's working..... and I don't know why. My assumption is when you use the pages wizard, it creates all the code. One thing I learned is how to update the server behavior to identify server folder(s) and create thumbnails.
