Error on php 5.4 for Pear Mail
Thread began 2/16/2015 1:34 pm by Larry | Last modified 4/06/2015 9:25 am by Ray Borduin | 5336 views | 7 replies |
Larry
Trying to use Pear Mail on Godaddy Cpanel. I am getting the following error
Fatal error: Class 'Net_SMTP' not found in /home/mores2015/php/Mail/smtp.php on line 349
It is installed though
Mail 1.2.0
Net_SMTP 1.6.2
This is a hosting configuration issue not a WebAssist issue, you should contact GoDaddy support. they should be able to get Pear Mail configured correctly on your host for you.
Larry
Will try that.
thanks
CraigRBeta Tester
Hi Larry
Did you get any joy with godaddy ?
I just installed PEAR for a client and get the same error.
Their guy in customer support suggested it was an error in my script !!
Larry
I was never able to get it to work. Godaddy hid behind they don't support 3rd party apps or something. We had to abandoned it and went different route.
CraigRBeta Tester
Sounds Familiar
I just spent 1.5 hours on the phone to them.
I know the problem is at their end, if could debug it better...
php 5.4.37
UPDATE
Tried mail2 package and its associated files, but it looks as though PEAR_Mail_using_SMTP_php.php cant cope with this
You need to have both PEAR and NET_smtp installed on the server:
see:
http://pear.php.net/package/Net_SMTP/download
http://pear.php.net/package/Net_Socket/download
If you have shell access you can run:
sudo pear install Net_SMTP
CraigRBeta Tester
thanks for the reply Ray
I have Mail, Net_SMTP, Net_Socket and Auth_SASL installed, (the other packages install by default on godaddy anyway).
I checked the server, the files seem to be there. the problem stems from line 349
$this->_smtp = &new Net_SMTP($this->host,
*UPDATE*
I checked the file locations compared to another host I use - just the same.
So I changed the file path in smtp.php on line 348 from relative to absolute
include_once 'Net/SMTP.php';
to
include_once '/absolutepath/Net/SMTP.php';
This gave me a different error about being unable to find Socket.php
So in SMTP.php I changed the path on line 22
from
require_once 'Net/Socket.php';
to
require_once '/absolutepath/Net/Socket.php';
This then reloads the page without errors. (and adds an entry to the email log), so all i had to do next was configure the port and username settings.
Success !! - but I won't be recommending godaddy as a host ;-(
