mysql query ignoring part of WHERE statement
Thread began 1/20/2015 6:49 pm by david | Last modified 1/21/2015 2:10 pm by Jason Byrnes | 364 views | 3 replies |
david
Hey guys, I've hound myself up against another wall... I have the following select statement ...
"SELECT campain_info.idCampaign, campain_info.couponTitle, campain_info.couponExcerpt, campain_info.couponDetails, campain_info.couponRetailPrice, campain_info.couponPrice, campain_info.amountSavings, campain_info.percentSavings, campain_info.expDate, campain_info.limitedQuantity AS 'Qty', campain_info.image, campain_info.localMarket, campain_info.tags, categories.idCategories, categories.categoryName, categories.categoryIcon, merchants.companyName, merchants.compnayWebsite, order_details.idDetails, Sum( CASE WHEN order_details.idDetails IS NOT NULL THEN 1 ELSE 0 END) AS 'Qty_Sold'
FROM campain_info INNER JOIN categories ON campain_info.categoryId = categories.idCategories INNER JOIN merchants ON campain_info.merchants_idMerchants = merchants.idMerchants LEFT OUTER JOIN order_details ON campain_info.idCampaign = order_details.campain_info_idCampaign
WHERE campain_info.expDate > CURDATE() AND campain_info.localMarket LIKE '$lm' AND campain_info.tags LIKE '$search' AND campain_info.limitedQuantity != 'Qty_Sold'
GROUP BY campain_info.idCampaign"
Everything works perfectly except that the final AND in the WHERE clause doesn't affect the return. For example, one of my campaigns has an available qty of 4, and even though the record set displays 4 has the qnty sold it is still returned in the record set. I've also tried > and <> in place of !=
Can you guys take a look at my select statement and see if I made an error OR if what i'm trying to accomplish can't be done this way?
you have quantity sold set to return 1 or 0:
4 is not equal to 0
Also, i don't think you can compare alias values returned from aggregate functions in the where clause, i think you need to perform the aggregate function in the where for it work correctly.
If you need one on one help t figure this query out, I think this is more complex than I can help with in the forum, you should sign up for a premiere support ticket for this:
http://www.webassist.com/premier_request.php
david
The quantity sold was set to 1 so that for each row returned that was not NULL, would have the value of 1 and then when summed would create the total number of sold. After some more research I cam across something I've used before but totally forgot about ... the HAVING clause.
HAVING Qty > Qty_Sold
This did exactly what I needed.
Thanks Jason!
you're welcome.
