WADYN_CONN.htm - Javascript error?
Thread began 1/13/2015 2:30 pm by david | Last modified 8/12/2015 1:08 pm by Ray Borduin | 794 views | 7 replies |
david
Recently I was having trouble with the Google map i inserted into the page only working on my local, the live version wouldn't display anything. After reading some Tech Support forum notes I re-installed Data Assist to be sure I had the latest version. Since then, every time I open up this particular site that has Webassist code in it I get a Dreamweaver error alert box. I've attached a screen shot. If I open a different site on my local I do not get any error. I've tried to uninstall and reinstall Data Assist to no avail. I've also shut down and rebooted. Tried to find where to clear the cache but couldn't find where or how to do that. Has anyone seen or had this error? I couldn't find anything in the forums with this error.
Thanks guys
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
Then close Dreamweaver and Delete the Dreamweaver Cache file from the users configuration folder:
also, use your OS File System explorer to browse to the local site files and delate the _notes folder.
david
AWESOME!! So far so good. Again thanks Jason and as always, great customer support! Also, has anyone had an issue with Google Maps not displaying? It displays perfect on my local but not when live. I think it may have an issue with security warnings, because Explorer will display it only after I choose to display insecure content... Firefox and Safari don't display an option?
sounds like you are accessing the map through an SSL address, you may have to edit the code to use an HTTPS address to call the google script.
david
That is correct, the site is using SSL. Thanks Jason, I'll look into it!
you're welcome.
jdjackson
HAVE SAME ERROR
I have tried all the steps you mentioned but, still have the error. Anything else I can try short of a reinstall?
Thanks...John
Clearing the file cache .dat file should fix that error:
