Mysqli extension not seeing recordset.
Thread began 12/13/2014 9:37 pm by David | Last modified 12/16/2014 8:39 am by Jason Byrnes | 1222 views | 4 replies |
David
I have created a mysqli recordset and placed a field from it inside a table. When I click on "repeat selection", the dialogue opens, but it is not seeing the recordset.. I get the same error (no recordset found) if I use the Dataassist repeat table function.
I have tried removing and reinstalling the sqli extension and dataassist and that did solve the first problem I had. Before I was getting a javascript error. Now, no javascript error, but it isn't working.
Nathon Jones Web Design
Are using WebAssist > MYSQLi > MySQLi Repeat Region for the repeat region? You'll need to if you've using a MySQLi recordset.
Just a thought!
NJ
As Nathon suggests maker sure you are using the MySQLi repeat region behavior found in the insert panel under:
WebAssist -> MYSQLi -> MySQLi Repeat Region
Data Bridge is not compatible with MySQLi at this time, we re targeting the first quarter of 2015 for an upgrade to Data bridge that will include MySQLi support.
David
Thank you. It isn't actually showing up in the insert panel under WebAssist -> MYSQLi -> MySQLi Repeat Region.
I did find something similar under ServerBehaviors->WebAssist -> MYSQLi -> MySQLi Repeat Region.
Please advise if it should be showing up under the insert panel.
Sorry, Yes, I meant to say under the server behaviors panel,
