Power Messenger has a lot of mistakes.
Thread began 12/02/2014 11:28 am by Dariusz | Last modified 12/05/2014 7:15 am by Dariusz | 2406 views | 8 replies |
Dariusz
I have tried PM on localhost (XAMPP) and:
1. After adding a new user by admin panel or registration form there's no users in the database
(The Server Settings displays the result of the Server Diagnostic Check was OK and all the database tables automatically add to my database).
2. After adding a new user with the same e-mail It shows me that this e-mail already exist ! Where is it? Tabel kfm_users is empty ! But, admin user has been added to database!.
3. After registration none of emails have been sent.
4. After "create mailings" none of them have been sent.
5. Doesn't work return to "thanks!" page.
Could you find any solutions? Please.
Regards,
Dariusz Kalmus
you will not be able to test power messenger from a local XAMPP installation.
XAMPP does not install a mail server.
to test Power Messenger, you would need to install it on a remote server that has a mail server implemented.
on registering a user, it does not get added to the kfm_users table, a new user will be added to the pm1_users table.
Dariusz
Ok, thanks a lot! I thought about this reason.
Regards,
Dariusz Kalmus
you're welcome.
Dariusz
However something doesn't look well...
I send you some screen shots. First of all, connections with database on localhost must work without any problems. I agree with you sending mails will be impossible at localhost but however in another scripts after adding some parameters of SMTP I can send and receive e-mails superb.
Need I explain the screen shots? The sequence of numbers of files is very important.
What is it you are trying to demonstrate through the pictures.
Please describe the problem that each screen shot is supposed to demonstrate, without a description, i have no context.
Dariusz
Img 1. Registration Email mona@wp.pl
Img 2. After click 'Register' it goes to 'My Profile' in order to modify profile and options. I don't want to change any things. There is only one button down the page 'Udate'.
Img 3. So I click on 'Log Out".
Img 4. Click on 'Login'. Enter Email the same as registered one and click 'Log In'
Img 5. The Form doesn't take my registered Email and Password. I look on data base.
Img 6. There is the Email in the data base !
Therefore the forms doesn't work because we could not log in.
attached is an updated copy of the users login page to fix the problem.
users_login.php.zip
Dariusz
Now is good. If I encounter some difficulties I will ask you again.
Regards,
Darek
