dreamweaver crashes when trying to add session variables.
Thread began 11/06/2014 12:26 pm by sebastian | Last modified 11/06/2014 11:54 pm by sebastian | 582 views | 2 replies |
sebastian
When i add security assist pages like login.php page and registration.php, everything works fine.
However when i want to add my own web assist login form, (under insert > WebAssist> Form) after i choose what fields to compare in my users table, when i go to add a session variable, dreamweaver almost ALWAYS crashes. I don't know what it is.
If i have security assist create the pages, everything works fine. But if i add my own login it crashes when I'm in the session variable tab. This complicates things because it is hard to add my own styling to the page if security assist creates the pages on its own.
Does this happen to anyone else?
Very Annoying..
I have been able to reproduce this and will log a bug to have it looked at to be fixed in a future update.
I have found that if Create the login server behavior with only the standard UserID column for the sessions, then double click it in the server behaviors tab to edit the settings, it will allow me to set additional sessions on edit. It seams the crashing only happens when try to add session columns when initially creating the behavior.
sebastian
Thanks Jason, you've been a very big help. I will work around it by following the steps stated above. Waiting for the update
Thanks again
