I tried to modify a form. Also create a new form and failed to populate dynamic list. failed to edit form. validation toolkit doesn't work any data is accepted. no on blur validation. I am extremely disappointed.
Thread began 10/18/2014 8:47 am by WALID | Last modified 12/01/2014 10:44 am by Jason Byrnes | 3229 views | 12 replies |
WALID
Does FB provide client site validation on blur?
Also, Is there anyway to create a 4 column form?
Yes, In Data Bridge, form builder uses JQuery HTML 5 validate script for on blur validation.
If the query validation is not working, it may be a few problems, you may have conflicting jQuery library on the page, or some of the needed files may not have been uploaded to the server.
It is posible to create a 4 column form, but all take some editing to the design.
Int he form builder Wizard, Go to the Form design tab and click the pencil icon next to the from design. If the form is already created, you can click the Edit design Button in the property inspector.
you will need to edit the Form to set the number of columns and over all width, and also edit each of the form element types to set the width so they will fit the over all width you set for the form.
WALID
A problem with date formats
Hi Jason,
I have reviewed your replies to previous posts and they all fantastic, I am using WA date picker in the attached form, the local date format should be dd.mm.yy However, I could not submit the format required by the mysql db
Thank you
dates stored in the database need to be in the format:
yyyy-mm-dd
so on the page the form posts to you will need to add code to convert the date format, you date picker element is named varDateFrom, and the form actin is set to post to result1.php. so on the result1.php page add the following code at line 1 to convert the date format
if(isset($_POST['varDateFrom'])) {
$_POST['varDateFrom'] = date("Y-m-d", strtotime($_POST['varDateFrom']));
WALID
Error loading the extension
Hi Jason,
I had Data Bridge stopped working (clicking any of the extensions brings nothing). I removed DB using DW CC extension manager and reinstalled it. However, it remains forever after starting DW CC and finally an error message as in the attached file...
What is your OS?
What anti virus or Fire Wall software do you have installed? try disabling those while doing the installation.
aslo double check that you have enough free space on your system, if there is not enough free space on the system drive, the installer download will fail.
WALID
I dont have an antivirus, run on Windows 8 and have 62 GB free space. Firewall setting never changed. the only change i noticed is the recent windows update (today). I was not able to find an earlier restore point
Regardless of fire wall settings changing or not, try disabling the fire wall during the install.
WALID
I disable windows firewall and still having the same problem
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
