Can't send an email and don't get any errors....
Thread began 8/25/2009 9:18 pm by steve387748 | Last modified 9/02/2009 3:40 am by office377308 | 2136 views | 4 replies |
steve387748
New to the UE extension (just got it hours ago) and tried following the getting started guide. I also watched the video and followed along.
One question is that in the video it references getting some code based on the model being used. In my case, I'm using PHP. Where is this information obtained? In the video it appears to be some place that is not part of the UE behavior although everything prior to that page shown on the video was interaction with the UE behavior window.
Another question is around the plain text view of the body. Can the HTML preview (from the Body tab) have something completely different than the text tab? I tried inserting the php code shown on the video in the text tab's view after clicking edit, and the code appears there OK. I typed some random text in the HTML tab view to see if it would show up in an email.
Another question around using the PEAR module for mail. It asks for the path to the PEAR module which in my case is found within the PHP directory that's contained in WAMP's www folder. Is there a specific directory in the PEAR directory I should be pointing to or just use the PEAR root directory?
And finally, I saved all my work after creating a simple form based on the getting started guide, previewed the page in Firefox, entered some info including a legitimate email address and clicked submit. If it did anything, I can't tell because I saw no failure notice or anything else pop up to indicate mail was sent. I had it redirect to a page after clicking submit and that worked, but no mail ever shows up. Problem is that I don't know if it ever sent it or not. How or where would I look to see if the email was actually sent or an error was encountered?
I entered the SMTP info and port per my current ISP's setting to test the page. I tried both the email selection as well as the PEAR selection and couldn't tell if anything happened other than I've never gotten an email.
In the video where you select your server model it says this about the code you need:
choose your server model to download a zip file of code, open the file in a text editor
You can have different content in the html and the plain text, you should edit the html with the DW icon and the text with the pencil icon.
You will need to specify the PEAR root directory like you have mentioned. To help determine if the Universal Email server behavior was triggered you can specify a page for the redirect, this way you will go to that page when the server behavior occurs.
If you are having difficulty getting the email to send you should contact the admin for your SMTP server and ask if there are any entries in the logs for your attempted mail send.
steve387748
I'll go back and check out the video again. Didn't realize there was a link.
I did add a file for the redirect and when submitting the form it redirects to the page name I supplied. I assume that means the behavior worked OK.
I'm running WAMP on my Windows XP SP3 PC using PHP, Apache, and MySQL. I tried pointing to the PEAR directory to use mail with PEAR, as well as just the mail option. Neither seemed to result in an email being sent. Note that I'm using the SMTP mail server that's supplied with my DSL connection's ISP. I used the same info as I use for Outlook when sending and receiving email. Actually there isn't much to supply using this method with the standard mail object since all it requests is the smtp address (smtp.live.com for MSN). I normally have to use a login userID and a password when using Outlook to send mail.
Does this additional info make a difference?
thanks,
steve
Some users have problems getting mail to send with their ISP email settings. I think that doing this with PEAR is the way to go since it is unlikely that the mail server would allow you to send email without authentication.
Your path to PEAR should just point to the PEAR directory that you have, it is probably in your php folder. It is looking for the Mail.php file that is in this location, you can check it yourself to see if you have the folder and file there.
If you are having problems testing with your ISP email server it may be worth trying to use your own SMTP server locally. If you have XP pro you should have IIS available to you. If so you should try enabling the smtp server from here. If you need to install IIS to get this feature enabled just make sure that you stop the server web server so it does not interfere with your Apache server.
office377308
Originally Said By: steve387748
Hi Steve,
I found this quite confusing, too! I created a form and tried to send it following the getting started guide. There was no hint at all how to do such a basic thing. The php code could have been posted in the document.
This is the only drawback I found so far. all the other parameters are really well described and easy to use.
Thanks for bringing this up.
I found another issue if you send a form, the howto suggests to put this into the body area:
<?php foreach( $_POST as $pkey => $pval ) { ?>
<?php echo(str_replace("_"," ",$pkey).": ".($pval)); ?>
<?php } ?>
the result is ugly because there won't be any breaks after each field / value pair.
The second line should be:
<?php echo(str_replace("_"," ",$pkey).": ".($pval))."<br>"; ?>
instead.
Any suggestion how to simplify the "send form" option?
