activation
I have to activate both data bridge and eCart ever time I create a new site. Any help would be appreciated.
Activation is based on the MAc Address for the active network card. If the mac address changes for sdome reason, it will cause the need for reactivation
a couple of common scenarios are:
1) Changing the connection type. For example if you connect using a hard wired connection, then change to a wireless connection it will cause the need to reactivate.
2) VPN Software.
some VPN software will create a virtual network adapter that changes the MAC address.
