Filtering options
Thread began 8/21/2009 2:09 pm by ericl384787 | Last modified 8/21/2009 5:58 pm by Jimmy Wu | 1585 views | 1 replies |
ericl384787
Filtering options
Hello,
I am working on a chart where I am passing parameters to the Dynamic Web Chart to filter responses. However, what I have found is that it appears that I can only have one filter in the chart.
I have found a situation for one of our clients where I actually need to be able to have two parameters that I am filtering on. Is this possible? If so how would I do this?
Eric Lommatsch
Jimmy Wu
There is no way to add a filter on two parameters using the wizard, but if you are familiar with coding SQL you can change the query directly in [filename]_data[num].[serverLang] file to filter on more than one parameter.
