Freetools serial number is coming with unexpected error 0,
Thread began 4/07/2014 4:30 am by ethan | Last modified 4/10/2014 8:08 pm by Jason Byrnes | 2796 views | 7 replies |
ethan
Hello
Have tried downloading again to get a new code,
uninstall then reinstall, and refreshing workspace layout with no luck.
I am using Dreamweaver cs6 with the correct freetools version have tried restarting computer, deleting cache files and even reinstalling weaver itself.
Any other ideas?
I had it installed before and working no problem but all of a sudden it asked for activation code again.
I am running windows 7
I can genereate the license fil for you if you provide the serial number and the Mac Address for the active network card.
to find the Mac Address:
1) Go to the Start Menu -> Run. Type "cmd" and click on OK to bring up a command prompt.?
2) At the command prompt type "ipconfig /all > c:\\ipconfig.txt"?This will create a file in your C drive called ipconfig.txt. This file will have the MAC address in it.
attach the ipconfig file that is generated and the serial number in a private message, and I will generate the license file and send it to your email .
ethan
mac Address
Have sent private message thank you
See PM please
ethan
Sorry I missed that here they are in pm
See PM
ethan
Hello again thanks for the file it Still isn't working though. Copied it to appropriate folder and still asks for activation code upon startup.
Any other suggestions?
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
