Forgotten password page doesn't sent emails
Thread began 3/28/2014 10:33 am by stella | Last modified 3/31/2014 11:56 am by Jason Byrnes | 910 views | 8 replies |
stella
Hello,
I have a little problem. I have a page with the option to send a forgotten password and it doesn't work. It says 'Email failed to send. Please confirm your email settings with your hosting provider.' however i checked with my hosting provider and they advised to check my code. I have no idea what's wrong... the information for the server is correct.
Also i have a similar problem with the checkout emails.
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
stella
it's GoDaddy.com
I checked the spam, it's not there.
stella
Also i created a contact form and it is working just fine...
GoDaddy is notoriously problematic with getting php mail() funtions to work
somethings to check:
make sure that they have enabled sendmail for your account.
in the forgot email server behavior, make sure to use a valid email address for your go daddy domain as the from address
set the smtp server and port to:
smtpout.secureserver.net 25
in all honesty, I would recommend a different hosting platform like 1 and 1:
1 and 1
stella
Jason, Thank you for your reply!
I have another hosting provider ipage.com and it is working much better than godaddy...
For the future, do you think 1 and 1 is better than ipage?
I've never used ipage.com so cannot say if it is better or not.
I prefer any other hosting to GoDaddy though.
stella
Thank you! It seems that i fixed the problem... was trying different combinations. )
glad to hear it is working.
