File duplication, import to second domain
Thread began 8/20/2009 8:55 am by biz295654 | Last modified 8/20/2009 4:58 pm by biz295654 | 1215 views | 2 replies |
biz295654
I have developed a set of DataAssist and IRite files that I will be using on multiple sites. In my first test of duplication, I copied the folder containing the files, dropped into a new site. I was hoping to merely change the connection file and it would be ok. (Also duplicated mysql database, keeping the same tables, record names.) However, I was unable to find where the connection php reference lived to change it to the appropriate database. Can you advise where to look for this code? Thank you.
The best way to handle this will be to create a new connection file with the same name as the original. Not only is the connection name referenced, but there are multi[le references to variables created in the connection file, if the connection file is created using a different name, the variable will have a different name.
If the connection is created using the same name, the only thing that may need to be adjusted is the relative path to the connection in the connection include. The connection include will look li9ke:
<?php require_once('Connections/ConnectionName.php'); ?>
biz295654
excellent! thank you very much
