I have a contact form, but I want when a click the bottom a PDF generate with the information that I enter.
this is not supported by web assist software.
you would need to hand code this fictionality.
i did a quick google search and this was the first result:
http://answers.oreilly.com/topic/1414-how-to-generate-a-pdf-with-php/
Hi, i checked out the googled resource provided here and appreciate the PHP add-on library. Dynamic PDF-formatted output is easy to achieve with the recommended object-based library for PDF.
