Free Tools for Dreamweaver
I am trying to install the free tools extension, but Extension Manager tells me I need a newer version of Dreamweaver. I have CS5.5, which should be compatible.
this usually happens when you double click the MXP file to start the install.
open the CS5.5 extension manager, click the install link and browse to the MXP File instead.
In the Extension Manager, the "Install Extension" is grayed out and I am unable to click on it.
use the file menu -> install extension link.
if that doesn't work, you have a problem with the extension manager itself and should contact adobe support.
