login system
Thread began 12/19/2013 4:42 pm by Andre | Last modified 12/20/2013 10:50 am by Jason Byrnes | 1820 views | 5 replies |
Andre
login system
i am trying to setup a login system so when people login they get redirected to their personal page. Is this possible with webassist?
Basically each registered user will be given a unique ID & when they login they see all relevant data for their ID?
I have setup the Site Access pAge & when i register & then login it doesn't redirect me anywhere it just tells me im logged in can i get this to forward the client to a personalised page?
If this could be done would it be able to create these pages on the fly or would these have to be manually created for each user?
open the login page. on the server behaviors panel, double click the security assist authenticate user server behavior, here you can set the login success redirect.
when the user logs in, their ID is stored in a session, go to the session tab to see the name of the session that is created
on the login in success page, you can use that session to filter a recordset to return the users information
Andre
login system
I got the redirect done thanks, where do i see the session tab? is this in dreamweaver?
in the Authenticate user server behavior, there is a session tab to see the session that are saved on login.
Andre
Order form
If i have an order form on the page that they login, can i track the person who made the order dynamically?
Can i see the amount of times a person logs in to the system?
the order form should be separate from the login page.
we have a tutorial here for creating an order history page:
http://www.webassist.com/tutorials/Create-an-order-history-page
that is the basis for being able to track who placed orders.
to track the number of times a person logs in, you would need to add an insert behavior to record the login. one of our forum members wrote a tutorla here for that:
http://www.webassist.com/tutorials/Show-online-users
