Online
I want to see what user is login to the downloads pages
that is possible
that is possible
see the following tutorial:
http://www.webassist.com/tutorials/Show-online-users
I do teh step on the tutorial and when a login dosent put Y in connect user
I dont understand the Creating the check who is on page
I would need to see the code to troubleshoot.
please send a copy of your pages.
On the login page, edit the security assist authenticate user behavior and clear the success redirect, then edit the update record behavior and set the page to redirect to after update there.
The problem is that the page is redirecting after successful login before the update can happen.
I clear the security assist authenticate user behavior and clear the success redirect and update record behavior and set the page to redirect to after update there.
Dont work I dont see Y in the connect user in the database
