Search
I want to create a search page for some data that I have in the database
How I can do it
How I can do it
Run the data Assist wizard, in the wizard, select to create a search and results page.
all of our tutorials can be viewed on the following page:
http://www.webassist.com/tutorials
by setting the Show Tutorial Using option to "Data Bridge" and entering "search" in the "Including Keywords" filed, the first result that came up is this one:
http://www.webassist.com/tutorials/Create-a-search-page-that-displays-filtered-results
I only want to put the name of the user and display all the thing that user has downloads
There wont be a tutorial for that.
you will need to create a join query to join the users table table, the userdownloads table and the downloads table
and set the recordset to filter the name column using the form element in your search form.
For details on Join Queries, see the following page:
http://www.w3schools.com/sql/sql_join.asp
I crrate a data assit search but the give me an error that 0=0 is have to be near the line 1
send a copy of your page and a link where I can see the problem.
OK THAT FUCTION IS
I WANT WHEN I TYPE A LETTTER THAT APPEAR ALL THE NAME THAT HAVE WITH THAT LETTER
