Warning: require_once( /webassist/security_assist/helper_php php) [function require-once]: failed open stream: such file directory /home/fmedupxf/public_html/ssi/ch-ssi-nav-fmEd--starterPage php line 1 Fatal error: require_once() [function require]:
Thread began 9/16/2013 2:27 pm by DEE | Last modified 9/16/2013 6:39 pm by DEE | 3230 views | 2 replies |
DEE
Warning: require_once( /webassist/security_assist/helper_php php) [function require-once]: failed open stream: such file directory /home/fmedupxf/public_html/ssi/ch-ssi-nav-fmEd--starterPage php line 1 Fatal error: require_once() [function require]: Failed
Can you please dumb down this Warning until I understand. I have uploaded the involved pages numerous times
It all began when I tried to Hide/Show my Login button, I used the tut you told me to. It seems to me this is a step I should have done way back when I first created the menu. Once I unravel this problem I'll need to redress each and every page. 'Whew"
The whole warning goes:- ( I put in in "...")
"...Warning: require_once(../webassist/security_assist/helper_php.php) [function.require-once]: failed to open stream: No such file or directory in /home/fmedupxf/public_html/ssi/ch-ssi-nav-fmEd--starterPage.php on line 1
Fatal error: require_once() [function.require]: Failed opening required '../webassist/security_assist/helper_php.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/fmedupxf/public_html/ssi/ch-ssi-nav-fmEd--starterPage.php on line 1..."
Thank you Dee
the error means that the some files from the /webassist/security_assist/ folder are not on the server.
upload the entire webassist folder to the server.
DEE
As easy as that?
Thank you
Dee
