doesn't return results
Thread began 9/13/2013 1:05 pm by anonymous | Last modified 9/16/2013 2:00 pm by anonymous | 684 views | 7 replies |
anonymous
Hi, I'm trying to setup a search page that returns results on the same page where the search field is. I tried one version first and it kept bringing back all results regardless of the search term. I then edited again using the DataAssist Search tool. Now the page just comes back broken. I was wondering if you could take a peak and let me know where I'm messing up :-)
What's supposed to happen: The user enters a search term and clicks search. 6 db fields are checked for the search term. If the search term shows up in any record in one of the fields, that record (s) should be returned.
I'll attach the file. Please let me know if you need anything else. I'm looking for two answers... first, what's missing or wrong? 2, I'd like to know how to use the tool properly because I need to do this for two more pages and i'd like to use the tool.
Thanks a million
Nelson
It looks like the trigger you have used for the data Assist search behavior is Recordset rs_careers Is Empty.
You should use the search form as a trigger instead, see the PM
anonymous
Follow-up
Thanks, I'll look at that.
anonymous
Improved results but still not great. See comments in PM
about_careers_search_test.php
See PM
anonymous
Thanks again for the HUGE help!. so sorry... one last question. It's all looking good and I have added my where statement into the careers recordset (WHERE date_archive > CURDATE()) but when I test it, there's an OR between the date query and the webassist query... it should be an AND... how would I change that? Basically I want OR between the field compares AND it must be current (date compare)
Here's what the bit of code you set up for me says (the OR right after CURDATE()):
query: SELECT * FROM careers WHERE date_archive > CURDATE() OR ((category3 LIKE '%Nurse%') OR (competitionno LIKE '%Nurse%') OR (position_summary LIKE '%Nurse%')) ORDER BY category3 ASC
Thanks again
in the Data Assist Search server behavior, set the separator for the first search Criteria to AND.
anonymous
That did it! Changing the separator to AND resolved the issue. Thanks again for all the help.
