re: need file made to get past firewall attn: eric
Thread began 8/17/2009 10:16 am by ruffteam | Last modified 8/19/2009 10:29 am by ruffteam | 1612 views | 2 replies |
ruffteam
hello. I just purchased CSS Form Builder and need the file made so I can access it behind the firewall at SMC.
----- ipconfig for smc computer behind firewall -----
Windows IP Configuration
Host Name . . . . . . . . . . . . : eng20332
Primary Dns Suffix . . . . . . . : smc.edu
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : smc.edu
smc.edu
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : smc.edu
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controller
Physical Address. . . . . . . . . : 00-11-11-5A-62-7C
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 172.16.78.108
Subnet Mask . . . . . . . . . . . : 255.255.254.0
Default Gateway . . . . . . . . . : 172.16.78.1
DHCP Server . . . . . . . . . . . : 172.16.88.16
DNS Servers . . . . . . . . . . . : 192.92.124.3
192.92.124.1
Primary WINS Server . . . . . . . : 172.16.82.20
Secondary WINS Server . . . . . . : 192.92.124.1
Lease Obtained. . . . . . . . . . : Friday, April 24, 2009 10:45:30 PM
Lease Expires . . . . . . . . . . : Saturday, May 02, 2009 10:45:30 PM
Additional information:
thank you eric
david
ps where do I find the attached file when you send it?
Jimmy Wu
I have created a support ticket for you, the files will be sent to you in this ticket. You can check your ticket by visiting your support history:
ruffteam
re: close
thank you.
david
