login
I add to my database pcms2_users a field name Active
I want, when the user click the log in button if in the file active is a 1 they can enter to the download page
and popup a message than said you can enter to this page
on the login page, edit the Authenticate user behavior to store the Active column in a session variable.
int he Security Assist rules manager create a new rule as:
Allow If
Session Active = 1
the use the security assist show region behavior to show the message.
How I can made if the user enter the password incorrect more than one time how I can block that account
you would need to hand code this.
On login failure, set a session variable to 1. if they fail the login again set that session to 2.
then use an if statement to hide the login form if the session is equal to 2.
I create the
Allow If
Session Active = 1
but I have access to the download page
you need to add the access rule to the download page.
How I do that
I dont want the user enter to download page if he account is not actuve
use the security assist access pages manager to apply the access rule to the download page.
I add the rule
in the access pages manager
but I having access
I check and the instruction that you gave me
I dont work
I continues having access to the download page
