java script error trying edit ecart 5
Thread began 8/11/2013 4:27 pm by Christie | Last modified 8/13/2013 3:05 pm by Christie | 436 views | 8 replies |
Christie
I am trying to edit the ecart object and am getting this error. All was working just fine until today.
While executing timer in WA eCart Object.htm, the following JavaScript errors occurred:
At line 686 of file "macintosh HD:Users:my name:Library:Application Support:Adobe:Dreamweaver CS6:en_US:Configuration:Commands:WA ecart
Object.js":
unmatched ) in regular expression
Any help would be appreciated. Thanks.
Send a copy of the eCart object file in the WA_eCart folder of your site please.
Sounds like a corrupted rule, but i will need to examine the code to be sure.
Christie
I found the WA_eCart folder. Which file would be the eCart object?
it will contain the name of the eCart object your created. the default eCart object name is "eCart1" so the eCart object file would be named eCart1_PHP.php
if you used a different name, the eCart object file will use that name instead:
<objectName>_PHP.php
Christie
Ok I have it. Will try to attach it for you......
eCart1_PHP.php
the error is caused by the following code that was added to the cart file:
$gift = 0;
if (stripos($this->giftWrap, "yes") === 0) {
$gift = 6;
this hand coding ion the object file is causing the error.
Christie
Thank you. Question #1- What is the reason this code causes the conflict as the cart works just fine (except for the object edit feature)? Remember I was having problems due to the columns not working correctly because of a conflict with DWcs6. I then had to seek a bit of hand coding help.
Question #2 - Is it possible to edit the ecart object with hand coding and have the object edit feature work as it should?
1) on editing the eCart object, it needs to read the object file to determine the settings that are being used. your hand coding is not recognized by the translator that reads the code and translates it to the settings. this is causing the error.
2) No, once you start hand coding the eCart object file, you will not be able to use the Object Editor to make changes, even if it does not generate errors, it would over write your custom coding, since it would not be recognized by the editor.
instead of using the hand coding for adding the giftwarp charge, you can do this on the calculations screen by editing the true price calculation to:
((abs([giftWrap] == 'yes')?6:0) + [Price]) * [Quantity]
undo the hand editing, then edit the cart object using the above calculation.
Christie
Great and thank you. Will try this.
