Admin back-end Results page
Thread began 7/10/2013 9:39 pm by Freddy | Last modified 7/11/2013 7:12 am by Jason Byrnes | 674 views | 1 replies |
Freddy
I have used DataAssist to create an admin back-end for my client's website. I have made it so that the Results page includes a Search form at the top.
However, initially it does Not display all the records in the database unless you specifically do a search first. It currently just says "No Results Found" when the page is loaded.
I need all the records to initially w show hen the Results page is loaded. And from there the user can use the search form to kind of filter out the results.
I have tried looking in within the php code but not really sure what to look for as I have extremely little experience/knowledge in php.
url to the page in question is here: http://zozayacreative.com/TLM/admin/boats_results.php
files are also attached.
Looking forward to your prompt response.
The recordset on the page is set to filter the BoatID column on the BoatID Url variable, if you want to return all results on initial page load, you need to remove that filter from the recordset.
