Log In page/Update Record Page
Thread began 6/11/2013 3:52 pm by Robert | Last modified 6/13/2013 12:11 pm by Robert | 1924 views | 17 replies |
Robert
I need to use MY OWN login form that takes me to my MY OWN update record page. I looked in the forum and under tutorials, but I didn''t seem to find an answers.
On the login form I used Security Assist Authenticate User, and on the Update Record page I created a Recordset where I filtered ID, and I used Update Single Record feature.
What am I missing in order to have the records display in the update form?
I attached the files.
Please Help, Thanks, Daniela
On the login page, the session being created is named ID
on the update page, you are filtering on a session named:
SecurityAssist_ID
change that to filter on the session being created at login:
ID
Robert
I made the changes. Still the update record fields are not pulling up the record info. I must be missing something else. I have been working on this for days....
LogInNew4.php
test7.php
to help troubleshoot, add the following code in the body of the update page:
echo("SQL: ".$query_rsAll."<br /><br />");
var_dump($_SESSION);
and this code at line 1:
@session_start();
Robert
I added the code. I get redirected to the wrong page.
couple of probelms:
1) on the test7.php page, you where using the Login Success access rule. I changed that to use the Logged in to AllList2 access rule instead.
2) in the webassist/security_assist/helpergrouprules.php file, the Logged in to AllList2 access rule was set up to use the SecurityAssist_ID session variable, your login page does not create that session, you must have renamed the session the login page was creating at some point.
i updated the rule to use the ID session that is created by the login.
3) you have not set the initial values for the form elements on the update page, i fixed this for the first one, you will need to fic the rest.
for each form element, select it in design view, in the property inspector, click the lightning bolt icon next to Initial Value. then select the corresponding column from the recordset.
Robert
Thanks for your assistance:) I still have 2 problems.
1) I am getting a message that is included below:
SQL: SELECT * FROM AllList2 WHERE ID = 4321
array(4) { ["WAENCRYPTEDRETURNUSED"]=> bool(false) ["WAENCRYPTEDRETURNSUCCESS"]=> bool(false) ["WAVT_LogInNew4_590_Errors"]=> string(0) "" ["ID"]=> string(4) "4321" }
2)Also, I can't update the form. The value is not changing in the database. What should I do?
1) That is from debug code i left behind, i removed it, sorry.
2) in the update behavior, you have bound each column to the recordset bindings, you need to use the form bindings instead.
Robert
Great! It is updating the database.
I am getting this error message:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/64/8292264/html/test7.php:2) in /home/content/64/8292264/html/test7.php on line 90
thats being caused by the blank line at line 1.
line 1 - 4 are:
<blank line>
@session_start();
the baln kline is causeing the error.
