cant see webassist
had to move to a new laptop. all my files are there but webassist doesn't show up in the insert pull down. what do I do?
You need to install the extensions.
Go to Commands Manage Extensions.
If you are using DW CS6, when updates are released, it overwrites the menus, so you need to disable the web assist extensions if they are listed, and re enable them,
if they are not listed in the extensions manager, you need to download them and install them.
