Multiple record insert gives error
Thread began 8/12/2009 11:35 am by jpj341892 | Last modified 8/19/2009 11:12 am by Eric Mittman | 3858 views | 3 replies |
jpj341892
I used the dataAssist Multiple Records Insert from Server behavior to get this done but I always get an error.
Microsoft JScript compilation error '800a03ee'
Expected ')'
/Insert.asp, line 7
var WA_loopedFields = new Array("ContactpersoonId", "Number/<%=(Names.Fields.Item("MeasureNamesID").Value)
I do know what the problem is but what every I tryed to get it fixed I always getting new errors. The problem is with " but I tryed every possible fix.
I use an asp page with <%@LANGUAGE="JAVASCRIPT" CODEPAGE="1252"%>
The page is working okay aslong as I don't use // WA DataAssist Multiple Inserts
Any idea how I can fix this.
Is this the entire line? It looks like the values for the server behavior would need to be updated. What did you set for the values when you configured this server behavior? It may have to do with how one of these values was entered that is causing this problem.
jpj341892
Mutiple records error
Please see the other posting there is all the correct information. I recreated the page but now with VBScript and the errors are the same. I have included the page in that posting. Thank you
Multiple insert not working posted in DataAssist
I have opened a ticket for you. Please login to WebAssist.com and visit your support history to update the ticket. Please include the files that are requested in the ticket.
I will respond to this thread after we determine what is going on and find a solution for it. Please do not respond to the other thread.
