Registration Form layout Problem
Thread began 3/19/2013 10:41 am by neil444064 | Last modified 3/19/2013 2:06 pm by Jason Byrnes | 1645 views | 9 replies |
neil444064
Hello, I used Security assist to create my regis system but when i include the registration form on my template page its layout gets broken up. See attached images. One is in Chrome and the other in FF. Can you help solve this? Thanks
For the fire fox issue, set the form width to be smaller.
for the chrome issue, i assume you mean the broken line on the left side of the navigation? For that you need to use the faux columns technique.
The Screen shoot looks like a CSS Sculptor layout? Int he CSS Sculptor wizard from design Extender, if you edit the design settings, you can select the Equal Column lengths to have the faux column technique applied automatically.
neil444064
Where can I fine more info on "faux column technique"? I did use CSS sulptor but modified it a bit.
Look in the how to section of the css sculptor support page:
css-sculptor/
neil444064
Why can't I use Css Sculptor to layout my site and simply include the registration page?
you could use framework builder plugins to add the registration page to another page based on the template.
neil444064
Can you give link to framework builder plugin?
Framework builder is a part of Design Extender and Data Bridge.
neil444064
This is impossible!!! I have been trying all day to get the regis form to fit in my template and cannot do so. I will now go and learn to code a form manually. I need help and you take 2-3 days to call back and my client gets angry. I am now done with this I have not accomplished a complete website yet in 3 months. Bye.
I only see one incident that I created for you on another problem, i requested contact details, but there was no reply.
I can start an incident of you like and walk you through this, or you can send a link and i can tell you what css needs to be adjusted.
