while executing findDynamicSources in WA_Validated_Entries.htm, a JavaScript error oc
Hi all
I've bought Data bridge a few days ago and i'm busy with my first tutorial "Create a Double Opt In Registration System"
The section where i receive the error is the second last section "Add url resend function". Here is the link to the tut:
data_bridge_create_double_opt_in_reg.php
When i click ok after completing step 12 "Set the Name to send" i get the error msg on dreamweaver (cs6) "while executing findDynamicSources in WA_Validated_Entries.htm, a JavaScript error occurred"
When i try and re-do step 12 i get a msg "you already have a variable named "send". Please enter a unique name" then if i press ok i get the javascript error above again.
Can i just continue? Is this normal? Can someone help me pls.
