super suite extensions crashing dreamweaver cs6, cache file does not solve.
Thread began 2/25/2013 6:13 am by nicole.meeuwenoord446136 | Last modified 2/27/2013 7:36 am by nicole.meeuwenoord446136 | 2641 views | 4 replies |
I recently downloaded and installed Dreamweaver super suite for my Dreamweaver cs6. I believe I correctly installed them into Adobe extension manager, however whenever I open Dreamweaver cs6, and try to import any of my super suite extensions, Dreamweaver crashes every time. I tried deleting the cache file, as instructed in the previous forums that were similar to my experience, yet deleting the cache file did not solve the problem.
I tried to view the tickets posted for problems that I similar to my experience, but I am unable to view them. Is there any solutions available to get my super suite extensions working in my Dreamweaver cs6? I am willing to try every possible avenue.
Thank you plenty in advance!
what extensions, including the version number are installed?
only the recent Design Extender, Data Bridge, eCart 5 and Free Tools extension are compatible with DW CS6, if you have the previous stand alone extension versions, you will either need to upgrade to the newer ones, or continue using the previous DW version.
if you are using the current versions, make sure to install in this order:
eCart 5
Free Tools
Design Extender
Data Bridge
Oh okay, that is probably the problem, I probably have the old super suite downloaded.
data assist
ecart 400
site import 205
site assist
Are these extensions are compatible with Dreamweaver cs5? or older?
or should I need to consider getting only Data Bridge extension?
Many Thank you's!
Data Assist, Ecart 4, Site Import and Site Assist are compatible with the older DW CS5 version.
you would need to upgrade to eCart5, Data Bridge (Which includes a newer version of Data Assist), and design Extender (Which includes newer versions of Site Import and Site Assist) in order to use the extensions in DW CS6.
Thank You!
