Do you support the WAMP bundle?
Do you support the WAMP bundle or do I need to stick with XAMPP?
if by support you mean "Will WebAssist software work on a WAMPP server" then yes.
The pages created by WebAssist software will work an a PHP / MySQL Server configuration. the method of installing PHP and MySQL is not relevant.
If you need help with problems on installing WAMPP though, then i would suggest the WAMPP Forums:
list.php?2
