Css menu writer
Thread began 8/10/2009 12:14 pm by meister281653 | Last modified 8/12/2009 1:12 pm by Jimmy Wu | 1620 views | 3 replies |
meister281653
Css menu writer
I need to ad some variables to my links, but they are not dynamic, just static but a variable like:
httt://www.mysite.de/editband.php?hash=565hfzrh4874hr84h428
I can ad it if I edit the php but I want it to be written down in the nice extensionwindow :-)))
Denis
Jimmy Wu
I'm not sure what you're looking for. You can add query string variables to the url manually in the wizard as well.
If you put this into the url:
that's where the menu item will link to including the query string variable.
Dynamic menus basically put a menu in the site for each item that's returned from the table (after filtering and sorting). Dynamic menus work differently in that you can either store the url in a database and directly output the database url into the menu or store the query string variable's value in the database and dynamically add that to each of the menu items that correspond to the database entries. You will still have to add the ?query_string_name= to get the variables added.
meister281653
ok, I described it a little wrong. The thing after the ? should be generated my PHP and that doesnt work like:
http://www.mysite.de/bands.php?hash=<php echo md5() ?>
that doesnt work.
Jimmy Wu
I understand what you're talking about now. I'll log a feature request and see if this will get implemented in a future release.
