Email fails when cms content is added to page
Thread began 1/09/2013 8:49 pm by jamie.ghio444407 | Last modified 1/10/2013 8:37 am by Jason Byrnes | 1433 views | 3 replies |
jamie.ghio444407
I made a blank page and added a simple contact form with create email and it worked fine. sent the user to the thankyou.php page.
Then I used Inset content from CMS. the CMS content loads fine, but the email does send but removes the domain from in front of thankyou.php when it goes to the goto page
<?php require_once('Connections/PowerCMSConnection.php'); ?>
<?php require_once("WA_CMS/WA_CMS.php"); ?>
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
if ((isset($_POST["submit"]) || isset($_POST["submit_x"]))) {
//WA Universal Email object="mail"
@session_write_close();
set_time_limit(0);
$EmailRef = "waue_mailtest_1";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "thankyou.php";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "picodgillo@yahoo.com";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
writeUEProgress($EmailRef,0,$TotalEmails,$TimeRemaining);
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
writeUEProgress($EmailRef,$LoopCount,$TotalEmails,round($TimeRemaining));
wa_sleep($WaitTime);
include("webassist/email/waue_mailtest_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
@session_start();
$_SESSION[$EmailRef."_Status"] = $GLOBALS[$EmailRef."_Status"];
$_SESSION[$EmailRef."_Index"] = $GLOBALS[$EmailRef."_Index"];
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
$_SESSION[$EmailRef."_To"] = $GLOBALS[$EmailRef."_To"];
$_SESSION[$EmailRef."_Subject"] = $GLOBALS[$EmailRef."_Subject"];
$_SESSION[$EmailRef."_Body"] = $GLOBALS[$EmailRef."_Body"];
$_SESSION[$EmailRef."_Header"] = $GLOBALS[$EmailRef."_Header"];
$_SESSION[$EmailRef."_Log"] = $GLOBALS[$EmailRef."_Log"];
if (function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
if ($GoToPage!="") {
header("Location: ".$GoToPage);
<head>
</head>
<body>
sadf<?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, '01 - Home Page', '01 - Top Banner'); ?>
<form id="form1" name="form1" method="post" action="">
<p>
<label for="name">Name:</label>
<input type="text" name="name" id="name" />
</p>
<p>
<label for="email">Email:</label>
<input type="text" name="email" id="email" />
</p>
<p>
<label for="message">Message:</label>
<textarea name="message" id="message" cols="45" rows="5"></textarea>
</p>
<p>
<input type="submit" name="submit" id="submit" value="Send" />
</p>
</form>
</body>
</html>
move line 2:
to be just before the doctype tag.
jamie.ghio444407
So, as a rule of thumb, do I need to always move the "<?php require_once("WA_CMS/WA_CMS.php"); ?> " when using email message and CMS content together on a particular page?
I noticed that the DW sprys stop working on pages with these 2 things also. Same reason maybe?
yes, that is correct.
i have not run into a problem with spry and UE/CMS. Spry is javascript based, so should not be effected by them.
i'd guess the problem is more to do with the CMS content it self.
