Log In ISSUE?!
Thread began 1/04/2013 7:30 am by debra444654 | Last modified 4/23/2013 6:40 am by Jason Byrnes | 2121 views | 9 replies |
debra444654
Log In ISSUE?!
I able to register a user which add the user to my database. Although, when I go to LOG IN that user, it keeps saying it's invalid?!
HELP! I'm not able to log in to users that are in the database.
First, double check that the server is properly able to store session information.
The following thread has a sessionTest page that can be used for this, if the session test fails, it is most likely a problem with the session.save_path setting in the php.ini file, you will need to contact the host to have them correct the problem.
if the test passes, send a coy of the login and registration page so i can inspect the code.
robcorrick409194
Hi Jason, I have the exact same problem, but I do not see you thread to do the test for session.save_path. Thanks.
the session test file can be found in this thread:
showpost.php?p=23826&postcount=2
robcorrick409194
Session Test
I conducted the session test from the thread above. The session ID did not change after I first set the session variable (clicked on the first link) and then tested the session variable (clicked on the second link). I still cannot get any user to login to the PM site after registration. Any suggestions? Thanks.
cliftonr254050
Login Issue after setting up user
I am having the same problem I tried to download the session test file but it wont download
here is a copy of the sessionTest.php file.
sessionTest.php.zip
cliftonr254050
I am having login problem
I ran the session test and every thing went ok, I also log into my database with phpmyadmin and look at "PM1_users" the two users that i enter is in the database just as i entered them and i still cannot login to PM.
Result:
Session Test = test and the Session ID did not change
