check out without registering possible?
Is it possible to let customers check-out without registering or logging in?
If so how? I can't find anything like that and client wants it....
If not, is there an work-around ? Please :(
the power checkout creates a registration automatically if the user is not registered for the site.
Power Store does not support no registration, the registration is needed for the order history.
thanks.... how does a customer get to their order history?
once logged in, Under the My Account Menu item, is a Sub Menu link to the order history
was that located in the upper header login, i removed that and just have the side menu... what file can i find the coding in to pick up and stick it into my side menu?
currently, when logged in it just shows "My Profile"
yes, it is located in the top menu.
see the webassist/plugins/main_menu/menu.php file for the link code.
