iRite - Error creating folder
Thread began 8/06/2009 1:30 pm by martin317528 | Last modified 9/28/2009 8:26 am by martin317528 | 6425 views | 8 replies |
martin317528
Hi. Despite having the correct path in iRite, when trying to upload files using iRite I'm getting: Error creating folder "/www/domains/mydomain.com/userfiles/image/" (mkdir() [<a href='plugins/function.mkdir'>function.mkdir</a>]: Permission denied).
I penned the path in iRate as /www.mydomain.com/client_files/ and various alternatives in config.php, but no joy.
(Linux server, Mac OSX running Dreamweaver CS4, PHP v5)
M
I nthe iRite config.php file, the $Config['UserFilesPath'] and $Config['UserFilesAbsolutePath'] variables should be set to be site root relative. If you want to upload files to
image/
then set those two variables as:
$Config['UserFilesPath'] = "userfiles/image/"
$Config['UserFilesAbsolutePath'] = "userfiles/image/"
If you still get the permission denied error message, try creating the folders "/userfiles/image/" manually at the root of you site and make sure to set the permission on the image folder to a minimum of 766 so that files can be uploaded.
james57944
No display of image
Setting:
$Config['UserFilesPath'] = '/images/cms/' ;
Allows file upload, but it will not display in the editor window (though the code shows up when viewing the html)
adding $Config['UserFilesAbsolutePath'] = '/images/cms/';
gives a "Can't create folder error"
Any Ideas?
I just discovered that the image is being assigned a height and width of "0". There's no way my client is going to know what to do with this.
Try removing the forward slash from the UserFilesPath and leaving the UserFilesAbsolutePath blank:
$Config['UserFilesPath'] = '/mages/cms/' ;
$Config['UserFilesAbsolutePath'] = '';
james57944
The files are uploading fine. However, the html that is inserted gives the image a height and width of "0". Hence, no visible image.
Shouldn't it include the images height and width?
Thanks,
Jim
This appears to be a bug in the FCKEditor using Fire Fox 3.0 and IE6, there may be other browsers affected, but those are the only two I could find a reference for on the FCKEditoer WebSite.
You can clear the 0's from the width and height to have the FCKEditor use the width and Height from the origianl image.
What browser version are you using, have you tried other browsers?
james57944
So is there going to be a patch for this?
Using FF 3.5.
Jim
It should be fixed in a future update to iRite.
martin317528
folder issue fixed
in config.php file:
Set the two variables as:
$Config['UserFilesPath'] = "/userfiles/" ;
$Config['UserFilesAbsolutePath'] = ;
(note: no "" in line 2)
making sure the actual folders are present where they should be (in this case the folder "userfiles" is in my root) and permissions are set.
Also check the Base HREF path is correct in iRite opening edit page:
WA_iRite/
