DataBridge Image Not Showing
Thread began 5/10/2012 1:50 pm by Doug Levy Designs | Last modified 5/11/2012 8:06 am by Jason Byrnes | 833 views | 3 replies |
Doug Levy Designs
I've created a catalog using your template many css issues but the real issue is the images for the products are being encrypted? on the server under images/products i get a tmp and a jpg
241503c3cdabb6e1da224a630f165882.jpg and 241503c3cdabb6e1da224a630f165882_tmp.jpg, when I test the cart the image is not showing and is looking for the original name of the file?
this usually happens if the upload exceeds the servers memory limit setting.
try adding the following code at line 1 of the insert and update pages that upload the image:
ini_set
("memory_limit""256M")
Doug Levy Designs
File size did not work
any other ideas?
