Error Opening DataAssist Pages
Thread began 5/03/2012 11:12 am by Doug Levy Designs | Last modified 5/29/2012 6:36 am by Jason Byrnes | 2712 views | 8 replies |
Doug Levy Designs
I've got a new installation of DataBridge and e-cart, I created a new php "blank" page and saved. I choose Webassist>DataAssist Pages and get two errors.
Error in makePreviews TypeError:pElm has no properties after clicking ok i get Error in uilnitialized TypeError wa.user_interface.preview_array(0).preview_oblect.cleanUpOld is not a function.
In another area, your documents show under insert>Webassist>"should show "DataAssist">DataAssist Wizard but i only show .e-cart, preset manager, get more extensions
thom389733
pElm error
Having the same issue here. Also why do I need ten words when "Me Too" should be sufficient?
Originally Said By: Doug Levy Designs
what other extensions are installed besides eCart and Data Bridge?
Did you install eCart 5.0.4 before installing Data Bridge? installing it after Data Bridge will cause errors.
Have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
With DataBridge, the access point for the dataAssist wizard is under Webassist -> Database -> Create DataAssist pages
the Insert - >Webassist -> DataAssist access point was for the older DataAssist 2
Doug Levy Designs
Reset Performed and Reloaded
I've reloaded in proper order and cleared .dat file, now when i try to use DataAssist Pages I get an error: Error in uilnitialize ReferenceError: xmlToObj is not defined.?
I also jsut tested SecurityAssist i'm getting more errors Panel 159 could not be created. Removing it from list after selecting ok get JavaScript error line 262 The object is not currently contained in a document?
other ext. seem to be working ok?
Current Extensions:
Tools for Google, Lightbox, Rss extension for dw, Drop-Down Obsidian Menu, Sitemap Everyday, EasyRotator, Paypal ecommerce toolKit, PalettePicker, HTML5 hinting for cs3 cs4, webassist.com PayPal ecommerce Toolkit, Ecart, DataBridge, Spry 1.6.1 Updater CS4
Doug Levy Designs
Still Have Issues
I tech called me and determined, that the files need to be saved "NOT OPENED" from download and e-cart must be installed before DataBridge, it appeared to work ok after we performed these actions, but we jsut did not go through far enough, on DataAssist Pages. Get 3 Errors:
Panel 163 could not be created removing from list
JavaScript error Line 149 Floaters\WA_SiteTools_ProgressV2.js SetPreferenceInt Argument number 3 invalid
onClick in WADA_Main.htm Line 262 Scripts\ListControlClass.js not in document.
There is also no current documents to learn how this systems works, so much for trying it our for two weeks!
We have identified this error as a problem in DWCS4, w will be releasing an update in the next couple of days to address the problems.
Doug Levy Designs
ReCaptcha not showing on webassist Fourm
For some reason when i try to post a new thread or reply to some others, the image verification is not showing. This makes it very difficult to get help. Can you please shed some light on this.
Of course the image worked on this thread, which is why this question is here.
I have updated your account to an account level that does not require image verification.
