menu 'hides' behind youtube video
Thread began 4/21/2012 12:50 am by info97301 | Last modified 6/15/2012 2:02 pm by Sweens | 3725 views | 18 replies |
info97301
Hi
If I view homepage121b.php?DistrictNo=1180 with Firefox, everything's fine.
However, if I view it with either IE or Chrome, the 2nd and 3rd tiers of the menu are behind the video on that page.
Is there a quick fix?
add wmode=transparent to the you tube embed url.
change:
<embed height="390" src="http://www.youtube.com/v/Ubqc7_MnBeE?version=3&autoplay=0" type="application/x-shockwave-flash" width="610">
<embed height="390" src="http://www.youtube.com/v/Ubqc7_MnBeE?version=3&autoplay=0&wmode=transparent" type="application/x-shockwave-flash" width="610">
info97301
Brilliant!
many thanks
Chris
info97301
Hi Jason
I wonder if this is something similar:
I have a test page: homepage121b.php?ClubID=1103
I'm trying to modify it so that the tab content is only called when the tab is clicked.
homepage121c.php?ClubID=1103
If you click tab3 on the second page, you can see that the Google Map isn't displayed - but if you click the 'map' graphic, it is displayed on that page.
The contents of the two is the same - but the map is not displayed for some reason in the tabbed panel.
Is there a similar setting (to the one you've given me) I need to change somewhere to get it to show?
Many thanks
Chris
see this thread for details on fixing this issue:
showthread.php?t=13541
info97301
Thanks Jason - but unfortunately the code is now quite different (perhaps things changed with new versions)
The only .js file in the google_javascript folder is wagmp_maps.js which contains only the following code:
window.onunload = function() {
GUnload();
/*wagmp_onload*/
if(window.wagmp_map_3) wagmp_map_3();
I have attached my wagmp_map_3.php file - but that doesn't contain any code similar to the example on the other post.
Cheers
Chris
wagmp_map_3.php.txt
Sweens
Hi jason
Not aure whether to add the post to the other thread or not - don't want to cross-post!
However, it is not working.
Cheers
Chris
with the V3 api, it's a little different.
you need to add an onclick event to the tabbed panel tab to reload the map:
for example:
<li class="TabbedPanelsTab" tabindex="0" onclick="setTimeout('google.maps.event.trigger(wagmp_map_3_obj.obj, \'resize\') ',100);">Tab 2</li>
Sweens
Thanks Jason
The tab loads the map and other data from a different page.
I've tried combining the two onclick events into one:
<li class="TabbedPanelsTab" onclick="tab3.loadContent('tab-map2.php?ClubID=<?php echo $_GET['ClubID']; ?>');setTimeout('google.maps.event.trigger(wagmp_map_3_obj.obj, \'resize\') ',100);return false;">meeting information</li>
but this doesn't work (I've tried several variants, but same result.
Wondering if I needed to put it on the tab-map2 page, I tried
<body onload="setTimeout('google.maps.event.trigger(wagmp_map_3_obj.obj, \'resize\') ',100);"
But this doesn't work either!
Any other ideas?
Many thanks
Chris
send a link please where i can see the problem
