Image upload w/file name
Thread began 4/19/2012 12:20 pm by anonymous | Last modified 4/20/2012 9:20 am by anonymous | 5983 views | 7 replies |
anonymous
I just finishing up an insert page (with MUCH help from tech guru Pat). I added an upload file function for the photo which is working fine - but I also need to have the form add the photo file name to the database. Is there a tutorial for this?
On the data assist support page, there is a tutorial for adding file upload using Digital File pro to data assist pages.
Digital File pro has been replaced by the File manipulations -> uploads file, but the steps in the tutorial are the same.
anonymous
Insert perfect, lost page redirect
Thanks Jason. My insert page is working perfectly, but since I added the file upload, I've lost the page redirect function. Any clues?
most likely a php error is causing the redirect to fail.
add the following code to line 1 to turn on error reporting:
error_reporting
(E_ALL);
anonymous
no errors
OK Jason. It's not showing any errors. If I remove the upload file function, the redirect is fine.
anonymous
Error
Sorry. I did get an error message when I submitted the form.
Warning: Cannot modify header information - headers already sent by (output started at /Applications/MAMP/htdocs/lthsBoosters_site/admin/add.php:207) in /Applications/MAMP/htdocs/lthsBoosters_site/admin/add.php on line 241
Line 207 is the upload file script:
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "upload", "0", "", "JPG:60", $WA_UploadResult1_Params);
Just not sure how to fix this.
that error happens if there is blank space between php code blocks.
see the following thread for more details:
showthread.php?t=19285
anonymous
Thanks again
What an education I'm getting with this site! I'm almost done so you should have me out of your hair soon.
