Distance
Thread began 7/24/2009 11:14 pm by meister281653 | Last modified 7/30/2009 7:33 am by Ray Borduin | 2909 views | 5 replies |
meister281653
Distance
Hi there,
is it possible to get the distance with google maps?
the user logs into the site. And his adress is stored in session.
the user looks for a restaurant. Is it possible to check the distance between the user adress and the restaurant adress?
Cheers
Denis
Yes it is, but you would have to read the google API to figure it out...
if you go to: www.ypsibigscreens.com/
The checkout page has logic that will charge $1 per mile delivery that uses google to find the milage from the warehouse to the shipping location. That might be good code to use as a sample.
meister281653
Hi Ray,
thanks, but I cant find the code. Do I have to order something?
Denis
On the checkout page, there is an option.... at the very bottom... check here if you would like delivery. Checking that box initiates code that calculates the distance.
meister281653
Ray,
I cant look into the source code. I see that it calculates the price, but I cant see the code.
Denis
I just right-clicked and went to view->source and found this function in the header:
function distanceCalculate(){
var from = document.getElementById("street1").value+", "+document.getElementById("city").value+", "+document.getElementById("state_province").value+", "+document.getElementById("postcode").value;
var to = "add your address here";
var oDir = new GDirections(null, null); // new directions object
GEvent.addListener(oDir, 'load', function(){
document.getElementById("distance").value= Math.round(parseFloat(oDir.getDistance().html)); // Fill miles into form
oDir.load('from: '+from+' to: '+to, {getSteps: true});
I removed some of the stuff you won't need, but there is a function that has all the necessary code.
