Setting up a Databases Connection
Thread began 2/27/2012 7:05 am by daniel387105 | Last modified 2/27/2012 11:51 am by Jason Byrnes | 1944 views | 3 replies |
daniel387105
Hi
question 1:
I need to export my databass from php myadmin how is this done?
question 2:
How to i import it on a local connect of Xampp?
question 3:
How to set up that databass connection in dreamweaver?
question 4:
How to add more pages to protect?
question 5:
How to change the redirect after registration of a new user, i need it to dirvert to a diferant page and not the one that it is going to?
1) A quick google search of:
phpmyadmin export database
found the following you tube video that you might find helpful
watch?v=Od25tkcsi5Q
2) searching google for:
phpmyadmin import database
finds this youtube video:
watch?v=IP7ZCRhubyA
3) On our learning resources page, we have a tutorial for "Creating your database connection in Dreamweaver"
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
4) Go to webassist -> Security Assist -> Manage Site Access -> Access Pages Manager. here you can select pages to protect and apply the access rule to them.
5) On the registration page, open the server behaviors panel, and double click the insert record behavior to change the after insert go to page.
daniel387105
Hi
Thanks thats great, i have exported it and im trying to import it but getting this error Error
SQL query:
-- Database: `wwwjust_radio`
-- Table structure for table `kfm_directories`
CREATETABLEIFNOTEXISTS`kfm_directories` (
`id` int( 11)NOTNULLAUTO_INCREMENT ,
`name` text,
`parent` int( 11)NOTNULL ,
`maxwidth` int( 11) default'0',
`maxheight` int( 11) default'0',
PRIMARYKEY (`id`)
) ENGINE=MYISAMDEFAULT CHARSET= utf8 AUTO_INCREMENT=2;
MySQL said:
#1046 - No database selected
your export does not include the create database and use database statements, since the export does not create the database, you need to create an empty one and select it in phpmyadmin before starting the import.
daniel387105
This post has been deleted.
daniel387105
daniel387105
daniel387105
